View Full Version : chip IU BLACK Minolta CF 3102
Astermarc
12-29-2009, 12:16 PM
Where I find chip from IU Black Minolta CF 3102? I have to change it (it's first time) and I don't know where is it. Any answer or picture will help. :(
KEVIN900
12-29-2009, 10:47 PM
Looking at the front of the Image Unit, as it's pulled a few inches out of the copier, you will see a black plastic cover that is held in by 5 screws. Remove that cover, and wiggle out of the way. It will hang from the blue corona cleaner. Behind that you'll find the small circuit board with a connector, and held in by a black plastic tab. Good Luck. It's easy once you know.
Astermarc
12-30-2009, 06:57 AM
Thx!!!! :)
Astermarc
12-30-2009, 07:24 AM
One small question? What u say isn't from the Bizhub C350?
Stirton.M
12-30-2009, 09:35 AM
From a physical point of view, they are very similar machines. Some of the technology has certainly changed, but the 350 and 3102 share the same lineage, just that the 350 was the first box born from the merger of Konica and Minolta. Later generations took on more Konica mechanical design tho.
