View Full Version : kyocera km 1500
HaSSaN010
01-02-2010, 10:28 AM
hello
i have km 1500 code error c-6 400
or 400 c-6
How do I fix wrong.
Is there a program, how to go there
I really appreciate your help me ,,..,,
hello
or 400 c-6
How do I fix wrong.
I really appreciate your help me ,,..,,hello friend ..well in km 1500 they not have the code error c-6 400 or 400 c-6 ...please to be clear ...because it have only ..c6400..so you can sure for this code error ...if you need more explain contacted me from my mail ...mecanopharme@hotmail.fr (...mecanopharme@hotmail.fr) ...l can healpe you my friend ..salam ...:)
hello
or 400 c-6
How do I fix wrong.
blackcat4866
01-02-2010, 06:34 PM
C6400 is a Zero-Cross Error. That means that the machine's power supply has detected a poor ground that interferes with the machines heat lamp control circuits. You'll need to do two things.
1) Contact a qualified electrician to resolve your dirty AC power.
2) Reset the error in simulation 163. This can be found in the manual.
Good luck. =^..^=
happicopy
02-02-2010, 05:20 PM
press stop/clear,print , light, stop. 000 will appear Enter '163' using the up/down keys n the counter key then press print key CLR will appear press print key twice then --- will appears, machine will reset it self wait for a while. you 'may' have a bad heater lamp if code reappears or you have defective thermistor and bad worn out fuser roller
