baba
01-09-2010, 01:04 PM
Hi,
I got a problem with my FS-C5020n. It says Call service 0952:0009760. I opened it and checked the wiring of the cyan print head (located on the drum unit DK510). The wiring is OK.
Can I swap the cyan drum with the magenta drum (swapping the developer and toner also) to find out wether the fault is located on the Drum Kit/Printhead (so the error code should change to 0953 then) or the PCB (then the error code should stay 0952)?
Other hints?
thank you, Bastian
Other hints?
thank you, Bastian
