View Full Version : Kyocera FS1030D Error
Geoff59
01-24-2010, 03:42 AM
My printer is showing the following code: On flashes green & Toner flashes red, then On & paper jam flash green and toner continues to flash red and the cycle continues.
Any idea what this code means? Printer has done around 54,000 copies.
madas
01-28-2010, 11:35 PM
The only code with the top and bottom light flashing is for waste toner full/nearly full. the code for that is slightly different to your discription.
top light = 1 bottom light = 4 the code is 1 2 4 flashing then 1 4 flashing shake the process unit from side to side to level the toner.
madas
