View Full Version : minolta 6001
aftabadil
02-05-2010, 05:54 AM
hi all
plz any body send me minolta 6001 default access admin password, bacz i change 6001 rom and now its demanding access code plz send me the default access password
The default admin password is 0000.
aftabadil
02-08-2010, 07:38 AM
its not worked still want password, what i do
brent
02-10-2010, 11:09 PM
I have had to replace ram's before and it is a pain. if you replace one and it needs a code. put the other ram back in the machine and get your information that you need. hopefully that will work
poz31
02-11-2010, 11:32 PM
I think you can go in tech mode stop ,zero ,stop, 1
And there is a way to reset the admin inside somewhere……
It has been a long time
If you can’t post you results and I will get back with my notes
brent
02-12-2010, 04:50 AM
the sad thing is that I have probably 15 of these machines out there. they still run very good. hard to get the customer to upgrade in these days. everyone is broke. anyways if you can not get this machine reset. let us know. and I will get the book out. as far as I can remember. when you replace a ram. you have to go back and put all the adjust numbers. A
and all the atdc figures and stuff. you have to write all that down on the front cover just in case you ever loose a ram. and then you have to go and tell the machine the marketing area and all the tech rep mode figures also. I have not had to replace one in about 5 years. let us know
brent
Nisar235
02-13-2010, 07:46 PM
hi
dear first go in user choice and then press key 6/6 then press admin# give code 0000 there you will see copy track data and you have to make it off and then press exit your problem will finish.
regards,
nisar khan
pakistan
