Konica Minolta 7255 Service Code SC5201
  • atechman
    • Feb 2010
    • 13
    Is anyone aware of what this code means?
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Looks like a problem with your DCPS. Is the code constant?
    Parts: Its what your copier craves!
    • atechman
      • Feb 2010
      • 13
      Konica Minolta 7255 constant SC 52-01
      Hello,
      Thank you for your quick response on this problem. I am a Ricoh specialist but am limited with Minolta knowledge. If I can assist you in any Ricoh questions, please let me know.
      I have reset the copier by turning the main switch on and off 6 times and unplugging the machine 6 times. So, yes the code does not reset. Is the DC power supply bad or may there be other possibilities for this code. Is this a service code that needs to be reset by a reset button or a service program mode?
      • Cantechman
        • Nov 2008
        • 228
        By looking at this I would first check the fan...
        Fan abnormality
        F52-01 FM13 (power supply cooling) EM signal
        was abnormal 2 seconds after
        turning ON FM13. 2 seconds after
        turning FM13 OFF and ON again, the
        signal is still abnormal.
        The machine stops
        immediately. RL1
        (main) is turned OFF.
        DCPS (DC power supply unit)
        • Coptech
          worker drone
          • 460
          The power supply cooling fan will be binding. KM will tell you that you need to replace the power supply as they don't offer a fan by itself. Tech support said you may be able to find a computer fan locally but I never had any luck. I did have luck with taking the finisher off, removing the lower left cover, cutting the mylar that covers the power supply fan, cleaning and lubing the fan. Worked more often than not.
          • RockETop
            Curmudgeon at large
            • Apr 2007
            • 171
            There is a fan for the 7022, 7130, 7228 series that has a compatible fan. You do have to splice the wires due to the connector being different. It works!
            • atechman
              • Feb 2010
              • 13
              Hello RockETop,
              Great intel on the cross reference list. Thank you so much for the quick response. You helped open my eyes. A definite asset yo the unit. Thank you!!!
              Best Regards,
              atechman
              • atechman
                • Feb 2010
                • 13
                Hello Coptech,
                Thank you for such a quick reply. Just like reading a manual. You are definitely an asset to the copier community. With 1.2mil on this bad boy, I think I will replace the assembly. Your right about taking the repair approach but the account is T&M and not willing to take the crap shoot. Once again, Thank you for leading me in the right direction.
                Best Regards,
                atechman
                • atechman
                  • Feb 2010
                  • 13
                  Hello Kmdurrin,
                  Thank you for the quick responce. Do you stock this part? It seems as if you may offer these parts. Once again, Thank you for your time.
                  Best Regards,
                  atechman
