View Full Version : c-203
hodgiepodgie
02-23-2010, 11:36 PM
how do i get into service mode and or reset password.is it same as nec 25c5 copier.how can i obtain a crossover chart for nec .bizhub etc
bizhub1
02-24-2010, 02:40 AM
To get in to service mode on these models, you hit -utility,meter count, details, stop 0,0, stop 0,1. Are you talking about the admin password you want to reset?
hodgiepodgie
02-24-2010, 03:47 PM
well service mode to replace image transfer belt. i am trained on the nec 25c5.when i tried to get into service mode the copier sked for password.
tech51
02-24-2010, 06:55 PM
If your just replacing the transfer belt you don't need service mode, it will re set automatically. However if you need to access service mode try this--
Description
How to access Service Mode when unable to use the normal procedure.
Solution
Service Mode can be accessed through the Trouble Reset screen using the below procedure: 1. TurnON the main power switch while holding the
UTILITY/COUNTER key.
2.When TROUBLE RESET appears on the touchscreen press STOP, 0, 0, STOP, 0, 1.
3.If prompted for a password enter 92729272 andtouch END. Hope this helps..
