View Full Version : copier lanier 6735 password
m_e_s_group
04-06-2007, 08:17 PM
please help me to reset the password of lanier 6735 .
JimBeam
04-19-2007, 03:50 PM
:confused: I don't know how to reset the password, but I can tell you how to bypass it so that you can use the machine!
Hold the 0 & 8 keys down while turning on power. Press 7, press START. There should be a 1 in the display. Change it to 0. Press interrupt to enter the new value. Press 0 & 9 simultaneously to escape and lock it in. Good luck.
m_e_s_group
04-23-2007, 02:26 AM
thanks for help but it does not work yet .
i want to cancel it . not to bypass
because i want to sell it .
copier cat
04-23-2007, 10:35 AM
hi,
The method to de activate the access mode is correctly listed. It will certainly work. Unless you have not pressed the interrupt to save the change of value from 1 ( p/w mode ) to 0 ( no control ).
REmember:
step 1: to turn on the m/c with 0 & 8 keys pressed down.
step 2: Enter the code 7 and press start
step 3: Change value to 0 ( as in ur case it shd be in 1 )
step 4: press interrupt ( to save the changes ).
step 5: press Energy saver button ( to test printing 1 copy )
step 6: all the above ok. press 0 & 9 together to exit the settings mode.
Now, your m/c shd not prompt for p/w anymore.
m_e_s_group
04-24-2007, 11:56 AM
thank you very much .
it works now without asking me for the password
thank you .
