View Full Version : Minolta LD6500
pg1309
03-06-2010, 01:22 PM
Hi
Why do the C6500 toner do not fit in the LD 6500 model? Why Why Why??? Toner codes for LD model:
A04P1F0,A04P2F0,A04P3F0,A04P4F0.
Pierre
kmcopier
03-06-2010, 08:16 PM
see other topic remove front cover and insert toner bottle you can see that the holder is the problem check your bottle's you can see the difference.
remove\ cut some plastic from from the holder and it fit's
pg1309
03-07-2010, 05:25 AM
Hi i did remove all the hppers also at the front of the toner i cut the plastic so it fit in the front but still after all that and i replace all the hoppers the printer show the screen that all 4 toners must be replaced? it is like at the front the toner do not open or soemthing? and how can the minolta know if there is no toner what sensor???
