View Full Version : How to deal with KONICA MINOLTA COLOR FORCE 8050 Report Code SC29-07 ERROR ???
mamianda
03-21-2010, 07:29 PM
I own a KONICA MINOLTA COLORFORCE 8050 machine and every time I turn it on, it prompts the following error message on the display screen:
Report Code SC29- 07
Tel - 0000905-890-1005
Fax- 0000905-890-4608
CAN SOMEONE TELL ME ON HOW TO RESOLVE THIS ISSUE? Or What could be the result of this error message? THanks in advance!
RRodgers
03-21-2010, 07:39 PM
Have ya tried to just turn it off (both switches) and turn it back on?
mamianda
03-21-2010, 07:47 PM
Yes, I tried shutting off BOTH swtiches and back on. It still didn't work. Any suggestions??
Thnx.
jotunn
03-21-2010, 08:31 PM
Clean up the Gamma sensor on Image Correction Unit, then try to turn machine off and on.
mamianda
03-22-2010, 12:18 AM
@ Jotunn- I'm not exactly sure where the Gamma sensor is located nor the Image Correction Unit. (Would you be able to send me a picture showing that so I can take it out and clean the sensor)? Please let me know. Or direct me to it. ??
Thanks!
jotunn
03-22-2010, 01:48 PM
Gamma sensor is located in the area surrounded by red ellipse on the photo - this is a module with couple of shutters.
37943795
florinliber
03-24-2010, 08:33 AM
Hello,
I have the same code error Sc 29-07 on CF 8050 machine,
cleaning the sensor does not solve the problem
What else I can do ?
jotunn
03-24-2010, 09:40 AM
That's interesting:
Revision of Print control program (Ver. 20 => Ver. 30) Image control program (Ver.20=>30) and Operation program (Ver.20 => 30)
2) Correction of IP-901 related failures
k. When the consumable reaches to over half of the life expectancy and the environment changes, SC29-07 may occur.
So maybe firmware update can help
florinliber
03-24-2010, 11:22 AM
jotunn = thanx for response
pls help me to understand how to do that.
I recently did gamma autoadjust from 3 6 mode and result was SC error code 29-09
RRodgers
03-25-2010, 06:49 AM
Check to make sure your Dev's are ok and not leaking out the sides.
F29-09 Dmax control /C resulted in an
abnormality.
Printer control board (PRCB)
Developing unit /C
Gamma sensor (PS11)
I've seen the gears wear out on the dev units as well, causing all kinds of probs.
error code sc 29-07There is a problem with this code Please help if there is an effective solution Program has been used1. Enter the 36 mode.2. "36 mode menu screen"Press the[3. Image quality adjustment] key.3. "Image quality mode menu screen"Press the [2. Printer gamma adjustment] key.4. "Printer gamma adjustment menu screen"Press the [2. Printer gamma sensor adj.]I shows error 31Program has been used2. "36 mode menu screen"Press the [1. Process adjustment] key.3. "Process adjustment menu screen"Press the [2. Drum peculiarity adjustment] key.4. "Drum peculiarity adjustment menu screen"Press the [3. Automatic gamma adjustment]I shows error code 29-07 Note Has been replaced by the developerI'm very tired of this holidays Please help
Has been replaced by the yellow developing unit and Clean the gamma sensor in the colour registration unit But the problem persists
I'm very tired of this device
It is the second I have the same problem in the two devices
Is it possible to have a role in this heat problem
Note that the device used before entering into Iraq
Because in Iraq No new devices
