View Full Version : DV UNIT C6500
xpedx102
03-26-2010, 06:32 AM
Any reason why the developer unit on the black would cause the following problem.
No matter the paper stock- if running paper fast- no problems- clean sheets
When running paper slow- get black smearing across half the page. Even on thin stock.
Happens on all paper trays. I know it is the DV unit because I took the unit out and installed on another C6500 and the problem followed.
Developer brand new
177k prints on the machine.
Any thoughts?
kmcopier
03-26-2010, 02:19 PM
Is the black toner recently exchanged?. What is the TC ratio?
xpedx102
03-26-2010, 03:01 PM
On the first machine, no I did not recently change the toner. On the second machine, I did. Sorry, What is TC ratio?
alexstl
03-31-2010, 06:01 AM
have seen this on an our machine, caused by toner clotted in dv unit ( customers uses machine and stock toners pipes in hight umidity and temp environment ).
Solved in this way:
vacumed toner hpopper
changed toner pipe in machine with a new fresh toner
made a lot of bk copies
Hope this helps
