View Full Version : Older Ricoh Firmware Updates without a pcmcia slot?
ezzysi
04-06-2010, 01:06 PM
Hi all
We're refurbishing some older Ricoh kit to go out in the field 2022' 27's etc and I need to upgrade the firmware to the latest available.
I've done this procedure several times in the past and have the required software/firmware/memory cards etc but i'm coming unstuck with not having a laptop that has a pcmcia port available to load Ricoh MCE onto.
Is there any other way to uprade the firmware on these machines or is there a usb>pcmcia adapter that anyone on here has used succesfully to to this?
I don't really want to have to source an old 2nd laptop just to do firmware uprades on a few machines.
Cheers
Simon
Jomama46
04-06-2010, 03:50 PM
There is such a beast but they aren't cheap. Here's one...PCMCIA Card Drive with USB interface (http://www.technooutlet.com/sy1991335.html?source=GGAN)
There are others, maybe try e-bay.
ccchuah
04-07-2010, 12:38 AM
Buy a PCMCIA adapter on PCI, insert on the desktop PCI slot. Thats all ! cost you around US 20 dollars
ezzysi
04-07-2010, 07:52 PM
Yeh I saw those and did consider one but it would be nice to be able to upgrade machines in the field too, and I only have 1 pcmcia card so couldn't pre-write all the firmware to take out with me.
sylerner
07-22-2011, 02:51 PM
Normally I don't reply to old threads, but having noticed that the cheapest solution never was mentioned, I thought I'd add some info for others searching the forum.
Rather than trying to find a USB to PCMCIA adapter at high cost, you can find very inexpensive Expresscard To PCMCIA adapter instead.
Since most modern laptops come with an Expresscard slot, you are able to retain portability.
Hope this helps someone down the road.
iMind
07-22-2011, 05:10 PM
Upgrade what, there´s nothing new for those machines...
techsass
07-23-2011, 02:26 AM
Wasn't there a way to do the firmware on the 20 series remotely? I remember doing a couple on the 2060s, but quit because the card was so much faster. Something along the lines of "IP addy/rimap:8080". Maybe not the right port, actually I can't remember if you even had to include the port.
iMind
07-23-2011, 10:30 AM
Upgrade what, there´s nothing new for those machines...Firmware Search - for Aficio 2027
Firmware type Files found Last updated on
Controller (1) 7-6-2006
DESS (1) 24-10-2007
FAX service card (3) 23-6-2004
GW (5) 3-3-2006
Language (2) 7-11-2003
LCDC (2) 2-12-2003
MFP Service Card (5) 7-6-2006
NET Service card (3) 23-6-2004
PS (1) 2-12-2003
SBICU (4) 10-12-2004
