View Full Version : Color Calibration
I been working on this for a long time, the printer controler on this machine (Lanier 5813 - 220V) just stoped working, I couldt reinstal system software so we dumped the controler. Recently I have replaced that controler with another one, originaly from Aficio 6513 - 110V. Now I just cant calibrate colors, when calibrated print is dark and has a strong magenta, when calibration is removed the print is also dark but yellowish. When printing CMYK from controler colors come out fine...Copys also come out fine...any ideas...Thanks
bjharrington
12-06-2010, 05:18 PM
Did you ever get this resolved? I'm having similar issues with my CF3102.
Tonerbomb
12-06-2010, 05:55 PM
did you try calibrating form CWS?? or just from the machine op panel?
bjharrington
12-06-2010, 06:13 PM
I tried from the panel. I just downloaded CWS, so I will try that now. I also read that it might be dirty AISD sensors. But not sure where to find those. Thanks.
After many work houres spent working on this problem I came up with solution. In Fiery color settings I just changeed RGB Separation value from Output to NONE. That solved My problem...
Greatings
bjharrington
12-08-2010, 03:38 PM
Thanks for the reply. I went into Setup Mode and under Color Setup the only choices for RGB Separation were "Output" and "Separation". I couldn't select "None". It was on "Output" so I'll try "Separation".
Thanks again for the help.
Tonerbomb
12-09-2010, 03:18 AM
That's FM, and shouldn't have anything to do with calibration.
