View Full Version : Mpc 6501 Paper type
dlums
04-08-2010, 05:28 AM
Hi All, is the Mpc 6501 capable of running 170gsm glossy paper through the trays, I have a customer that is having continuous jamming issues with this paper type even on thick paper 2 setting. Cheers
Rorschach
04-08-2010, 09:18 AM
Per the specs given in the FSD, you can run the following paper weights:
Trays 1 and 2
52.3 – 216 g/m2
14 Bond – 80 lb Cover
Tray 3
52.3 – 256 g/m2
14 Bond – 90 lb Cover
Bypass
52.3 – 300 g/m2
14 lb Bond– 110 lb Cover
Duplex mode
60 – 216 g/m2
17 lb Bond – 90 lb Index
Bear in mind, these specs are for bond, not glossy. Also, despite these specs, I'd give serious consideration to using the bypass, and setting it to thick 3.
dlums
04-08-2010, 09:28 AM
Thanks very much for the info, Unfortunately I do not have a bypass on the machine as it has an A3 Lct attached, if you set it to thick 3 you cannot duplex then, my customer needs to duplex.
I have a feeling that this model cannot tolerate gloss. Thanks for the help.
GhostInTheMachine
04-08-2010, 10:12 PM
This is the recommended glossy as per the Product Support Guide.
Kromekote
Laser High Gloss Cover C1S
Coated
49.07lb. Bond 184gsm
Kromekote
Coated
58.4lb. Bond 219gsm
Notes:
1. Poor feed or excessive curl may occur in high humidity environment.
msaeger
04-09-2010, 12:13 AM
What jam code are you getting ?
