scoobysteve
04-08-2010, 06:42 AM
Hi All,
I've come across a few FS-1300Ds now that have numerous jamming issues. Jam logs (ELOG) indicate in the hundreds for the J10 jams and the J11,12 and 20s not far off.
Currently, i'm getting jams where 1/4 of the A4 page has exited the top exit section, and a second sheet of paper half way through registration. A print out of the error log indicates that the paper has not passed the registration sensor (J10 - 48 jam). Could it be that the registration sensor is faulty? ie, it doesnt realise that the first sheet of paper has already passed through thus when the second sheet is currently over the sensor, it thinks that the first sheet is still there?
I've changed the mylar strips at registration to the modified ones just incase they may be warped/damaged but still get jams. I've changed all 3 (feed, rego and MPF) clutches (and magnetic clutches rarely tend to fail). I've even changed the whole drive unit (which included clutches) on another machine with identical problems and still no result - in the end the machine was swapped out by the manufacturer under warranty. Spring tension between the upper and lower registration rollers seem good - how would you test?
So if anyone can suggest something else to try, it would be much appreciated. thank you.
Kind Regards,
Steve
Kind Regards,
Steve
