View Full Version : c6500 fuser replacment
At what count should the fuser be replaced on a C6500?
ni311
04-20-2010, 05:23 PM
You don't have a deadline for the whole fusing unit in the service manual. But, from what I am remembering, fixing roller lower and paper exit roller should be changed at 200k, the fusing belt and sleeves 400k, gears and ball bearings at 600k.
I'm almost at 2 million and I have only changed the belts.
So I guess that is pusing it?
ni311
04-20-2010, 06:10 PM
You are very lucky if your fusing unit is still working after 2 million without changing anything else but fusing belts. It is pushing it a little too much, you should have ready gears, ball bearings, sleeves and sensors near by. Anyway, it is a wonder that all the gears are still working and still are in one piece.
Wow......I just couldn't believe it.
seniortech
04-20-2010, 07:38 PM
Fuser units in my machines run happily 800K to 1 million copies without any problems...
ni311
04-20-2010, 08:07 PM
I'm not so lucky, I always have issues with the fusing units around every 200k.
sbillis
05-07-2010, 06:09 PM
that sound very good but, what kind of paper stock is using on these machines please?
anything cheap or specific provided paper?
Herrmann
05-13-2010, 12:01 AM
There are three gears with a "one way clutch" in it, i would recommend you to replace them every 600k copies, otherwise you can run into c-3102 errors ;)
