View Full Version : Bizhub 210 crackling
MihaiGSM
04-21-2010, 06:19 PM
Hy all!
The copier has 160.000 copies on counter. A few days ago, it started to make crackling noise from imaging unit. I found the drum charged with developer at one side. I cleaned it, it worked about one day, but today started again to make crackling noise. The drum was again dirty at the same side. What must I check? The seals on the magnetic roller are good. Thanks in advance!
ni311
04-21-2010, 08:31 PM
Take it out and try to rotate the drum with your hands, you should hear the noise. Most likely one gear is broken.
mo0651
04-21-2010, 10:24 PM
It could be a partially torn transferbelt.
minimerlin
04-22-2010, 09:23 AM
It could be a partially torn transferbelt.On a BH210? I think you may be getting mixed with the color machines.
mo0651
04-22-2010, 02:31 PM
OOPS! Sorry I was thinking of different post. Any Way. Open the top of the imaging unit and look at the waste toner auger. sometimes mylar and little gears get loose in there.
