View Full Version : cf 2001 transfer belt unit fuse question
brent
05-05-2010, 05:43 PM
sorry to bug everyone again. I am in a pickle and need to reset this one. can anyone give me the specifics as I have not found the fuse on the belt unit. any thoughts?
thanks
brent
minimerlin
05-05-2010, 09:17 PM
As far as I remember, the fuse is located at the cleaner unit end. I think you can see two silver metal connector points that are the indication of its location. My memory is a bit faded on this unit but try looking at the rear of the unit.
I cant remember if you have to split the cleaning unit from the belt but something tells me the fuse is a bit awkward to get at, sorry I cant be more specific.
JDYAL
05-07-2010, 04:46 PM
Yeah its on the side of the unit with two metal tabs.First remove the metal guard then a tiny black screw the fuse is behind the plastic piece with the 2 metal tabs.
brent
05-10-2010, 04:11 PM
the only fuse rating I found here locally was a 250 v 500 milliamp.. so that is smaller then the 80 milliamp. will that work or will it not recognize it? I wish they had the right fuse here. as this one costs 5.48 any ideas?
thanks
brent
cobiray
05-10-2010, 04:54 PM
If you've got any fuses for resetting the IU's on the di250/350/200/251/351's you can use the same fuse even though it's a pico fuse and not the tube style.
