View Full Version : Xerox EXP50 Fiery
pg1309
05-05-2010, 07:41 PM
My fiery of my Xerox DC 5000 do not want to connect? My fiery IP is 127.0.0.1 i can ping it but not connect also in my browser i can not connect???? Any help
Milo Wilson
05-05-2010, 08:03 PM
Are you trying to connect thru the network or directly on the fiery? Does the Fiery have a monitor and keyboard?
pg1309
05-05-2010, 08:17 PM
Hi
Yes it is external Fiery, when i startup CWS it always got the fiery name and ip now when i connect i only get a error? I can ping the ip?
Milo Wilson
05-05-2010, 10:55 PM
If the server has Monitor and keyboard support, Start the CWS, before you log in to the CWS remove the server name then try to add it back. See if it will automatically detect if not , go to manual add and use "localhost" as the server name but only try to connect when the server says idle at the top of the screen.
JimmyB
05-06-2010, 11:41 AM
ip 127.0.0.1 is for "local host", you pinging your computer ....
try to change fiery ip to your LAN ip range.
exmple: if you computer ip is 192.168.0.2, set up fiery ip to 192.168.0.x (x=3-254)
Goshe
05-06-2010, 02:45 PM
I Agree
