View Full Version : Ricoh 1035
mike1025
05-10-2007, 07:26 PM
I have a message SC542 please call tech support number#...., Please any one advice how to reset this message and fix the problem, thank you
copyguy5
05-10-2007, 08:14 PM
You can find the Service Manuals at:
Index of /protectedmembers/180903/RA1035_1045master/SERVICE (http://www.copierprofessionals.com/protectedmembers/180903/RA1035_1045master/SERVICE/)
GOOD LUCK
copyguy5
jeffreyozz
05-10-2007, 08:27 PM
get into sps and turn off the main switch, when the machine reboots if there is no problem with the thermisters or the fuser itself it should be operational. air conditioning becomes a good source for these codes
Kopyrtek
05-10-2007, 10:01 PM
I have seen surge protectors cause this code also.
hosennet
05-11-2007, 10:40 AM
Hi
Try next way:
1. Input sp mode- exit- power off-power on
2.Check Heater lamp-230v 550w 335mm (AX430072)
Good luck
Herrmann
05-11-2007, 08:58 PM
Replace both Thermistors, they are known for being weak and cause much of Trouble.
Regards
Herrmann
blackthumb
05-18-2007, 04:57 PM
This is an "A" level code for Ricoh, and it usually involves the thermistors. I have seen this caused by a transparency wrapped into the thermistor, causing it to go out. Check continuity between one side of the fuser lamp contacts through the thermistors to the opposite side of the fuser. If continuity is present all across the fuser, reset the SC in the SP mode 7807, SC code reset. The machine must be completely powered off after you reset this code, then restarted to clear the code. You can also monitor the hot roller temps in sp 1106 (i think this is the right number, but the display will get you to the correct place) for both the roller end and center temps, once the SC is reset.
Tonerbomb
05-18-2007, 11:50 PM
if this happened after replacing the hot roller you may have installed the wrong roller, this was very common a few years back.
BPGTECK
05-19-2007, 04:02 AM
thats right tonerbomb thickness of the roller caused that problem
i remembered when i saw ur post
mrvibe
06-29-2007, 06:04 AM
i have seen this problem several times. after reseting the code listen for any type clicking noises coming from the fuser unit... that will indicate your hot roller isnt a genuine ricoh part. you will see the roller starting to warp then crack, but before this happens you will get the sp popping up to warn ya...:cool:
blackcat4866
08-22-2007, 01:10 PM
The SC542 is a fuser temperature warm up error. I caused this problem myself once when I installed an AF350 hot roller in an 1035. The thicker roller did not warm up quick enough to suite the main board. (Quick Start-Up Technology= thinner fuser roller).
bluemax121
05-27-2008, 04:27 AM
hi
i have recoh 1045 5 mehines igot problam as sc440 in 2 mechins
plz help me to downlode a service manuel
kindly
thanqu
etsmultan
05-27-2008, 05:35 AM
first go to service mode and then reset 5#801# and 5#810# and then if code appear 329 u hve to reset by 5401#
etsmultan
05-27-2008, 05:40 AM
sorry reset by 5801
imaginemoko
05-27-2008, 07:29 PM
check the thermostat if still has its continuity? if none replace same as the thermistor.... for time bieng go to sp mode turn off/ on the machine to reset the code.. but replace it as soon as possible..
ZeusGT
05-30-2008, 02:13 AM
Make sure the thermistors are in good shape i.e no toner buildup on the tips. I would recomend replacing them anyway. Check to make sure that the lamps are good by checking the resistance. If you still have the problem, then I would make sure that the thermostats are not blown. Take them out and shake them lightly. If they rattle, then they are good... if not then the porcelain rod inside has made contact causing the electrical path to be blocked...then they will need to be replaced.
FRIDGEMAGNET
05-30-2008, 07:11 AM
If you need a service manual then there is a dedicated section of this site and they are very reasonably priced.
Ricoh-ono
05-31-2008, 07:54 PM
Call a Ricoh dealer in your area to fix your machine.
Jomama46
05-31-2008, 08:42 PM
This means its time for some barrierta and bearings
petrus
06-02-2008, 07:45 AM
Try this.....reseting the sc code by using sp7807 then off/on the macine.
if still appear check both of the thermostate.if it alive then the thermister on centre dead.
but if this problem appear after you change the hot roller,that mean the hot roller is too thick compare the previous hot roller.cause the temperature arise slower the before.
DetriotTech
06-04-2008, 05:48 AM
One thing I have encountered is after replacing all the components everyone else has listed. I still had intermit. problems. It turned out to be a bad fuser connection at the machine frame.
bubbabear
07-31-2008, 12:09 AM
Has anyone been able to network scan off of a Aficio 1035p or 1022 using Desktop Binder?
I tried it with both Windows XP as well as Vista and there appears to be no communication between the copier and the computer.
Is this because it isn't compatible or is it because the firewall the computer is on is blocking it? If it is the firewall, which port numbers need to be opened in order to get it to work?
I've tried using it at different job sites for different customers and not one of them has been able to see the scanner.
schooltech
07-31-2008, 01:02 AM
I did find this for desktop binder, if it helps. I haven't used desktop binder in quite a while.
Also, Tonerbomb has posted stuff on Vista scanning.
bubbabear
07-31-2008, 02:53 AM
I'll try this out. I haven't been able to get a 1022 series to do network scanning at all. In fact I have noticed that it recognizes all the print monitor functions but not the scanner. I know that network scanning has always been a problem to run on these machines because Ricoh provided it but it never worked as it was inteneded to do. 2035 series haven't been a problem.
Thanks for your help.
