jonbonse
05-15-2010, 12:05 PM
Hi all
I have a client with a Xerox 3040 which has bad background problem.
The whole page is covered in background.
I have checked the drum and cleaning blade and found the charge corona wires had been arcing so cleaning up free from toner.
Cleaned the erase lamp and detack free from toner.
I found spilt dev around the dev bias contact areas so i vacced that out free from dev.
The high voltage board had dev round the back of it also so vacced out what I could see.
The fuser assy is ok.
I have put back together and tested but this time the page was half covered in background, but then after 5 - 10 copies, the background is now only 2-3 inches from the edge of the copies.
I need to replace the drum as it is scorched so will replace the cleaning blade at the same time. I am going to replace the cahrge corona assy due to the arcing and the mag roller bushings to prevent future dev spillage.
The platen is scratched so that will be replaced.
The LED assy looks ok and the optics lamp is illuminating ok.
Is there anything else that can cause the background problem?
One more thing I noticed was when i was vaccing out the spilt dev in the left door assy, I kept getting a little electric shock from the rubber vac tube when It was touching the door! The machine was unplugged at the time.
Im wondering if I have got all the spilt dev from behind the High voltage board?
Any help is much appreciated!
