View Full Version : how can i use the scan to pc of bizhub c252
remielee
05-27-2010, 06:03 PM
hello guys i dont know how to use the scanner of my bizhub c252 i want to scan a document then send to my pc, do i need to install a software? wait for your reply guys, thanks in advance....
You can use SMB , no software needed .Just log into to your copier via the web page and set up SMB. Create a folder on your C: drive and call it scan make sure the folder is shared and can be modified by other users , then create a shortcut of that folder on your desktop. For the file path type in \\ ip address of your pc\scan.That should cover most of it.
remielee
05-27-2010, 09:02 PM
thank you sir rudi the connection is peer to peer only and not a network but anyway i will try it sir thnk you very much i will repost a reply
Bskinner
05-28-2010, 02:36 AM
SMB should still work on a peer to peer network
