edrummie
05-31-2010, 07:04 PM
I've had this 8031 for 2years. I've replaced a number of Toners and Imaging units, as well as the Fuser and Transfer Roller - all without incedent. I tracked down the Tech password and reset the counters for the Ozone Filter and the Transfer roller (to clear the messages off the display).
However, I recently replace a Cyan Imaging Unit last week and it printed a test page and 20-30 pages fine until it started to misplace color. It has also started to 'grind' when the motor is getting started, like a gear is mis-stepping or slipping 'clunk - clunk - clunk' in the back. On it's own - this does not create an error at startup, but if I try to print or copy - it happens again, just as the printer is getting ready to print and I get the C1220 code.
8031 with Duplex and Finisher, 3Xe Fiery Driver. Room temperature is a bit high at 23C/75F.
Image Transfer Belt is just over half
Thanks, E.
Thanks, E.
