View Full Version : Document Scan using Pi3502 for Minolta Copiers
Bsmith
06-02-2010, 08:48 PM
I have just installed Pi3502 on Minolta copier, it works OK for printing. I want to enable the scan mode, what do I have to Do?
Thanks,
Morlock49
06-03-2010, 04:43 AM
make sure the Postscript / Scan and 128meg upgrades are fitted to the Pi3502
TheOwl
06-03-2010, 07:55 AM
Agreed with Morlock. You must have these options.
Open up the Pi3502 and you should find a Smart Card card slot. This slot should have the upgrade kit (smart card) inserted before scanning then becomes available.
Bsmith
06-03-2010, 04:02 PM
Thanks for the direction!
Please direct me to the source of the smart card.
TheOwl
06-03-2010, 11:46 PM
You would need to find one on ebay or a Konica Minolta reseller.
Chances are that you will have tough time finding the upgrade and it might be easier to find another Pi3502 with the scanner upgrade already installed.
Morlock49
06-04-2010, 03:24 AM
also it is probably going to cost you an arm and a leg for the postscript/scan kit. last one i seen for sale was over $350.00 and now they are getting rarer than rocking horse crap.
Hansoon
06-04-2010, 06:05 AM
I still have some from returning rentals.
Send me a PM or an e-mail nospam@rex-technika.com
Hans
Bsmith
06-04-2010, 03:21 PM
Hansoon,
An email is sent to you with my contact information and shipping address.
Thanks for help!!
BSmith
Apostolis
06-04-2010, 09:20 PM
this upgrate memory for the Pi3502/5501/4700e controllers its a simple old 128Mb/ PC100-122Mhz one side memory.Its chipest - if you find
Bsmith
06-07-2010, 03:32 PM
Dear Apostolis,
Thanks for the details of th memory stick. I can look around and get one.
Second item is the issue, do you know any source for the second item?
Apostolis
06-07-2010, 10:02 PM
the scanner work fine too,with 64MB-PC100/PC133 one side (84 pin) SDRAM memorie's .If it's hard to find one side (84pin) SDRAM 128MB or 64MB-PC100/PC133,
you can use 256MB-PC100/PC133 two side (168pin) SDRAM , In this case the controller will accept the one side (128MB) of the sdram.I think you can find on ebay this memories and the minolta PS module.
