View Full Version : Konica minolta bizhub c350 help!!!!
gitana1983
06-11-2010, 10:17 PM
I need to know if this machine has a laser beam, i have looked through the manual without luck, have the machine in parts and still ca find it.... Can anybody please point me in the right direction??? Does it have a laser beam? Is it called different? Please help!
Thanks in advance for the help
Dave10
06-11-2010, 10:23 PM
It does not have a laser. It has 4 LED print heads. They are the long strips that run front to back of the machine between the drum units.
gitana1983
06-11-2010, 10:27 PM
it does not have a laser. It has 4 led print heads. They are the long strips that run front to back of the machine between the drum units.
they are in the lph unit? Just want to make sure.
Dave10
06-11-2010, 11:27 PM
Yes. If you take out the drum units, they sit between them running front to back. They are mounted on a plastic frame that holds all 4. Together, they make up the print head unit.
Stirton.M
06-12-2010, 01:46 AM
See attached file that has the parts breakdown of the print head unit assembly.
Note that the black LED unit is a different part number from the colour units.
