View Full Version : Electrical konica 7155 "close front door" message
Kevin Ransom
07-01-2010, 07:20 PM
adu driver pwb, print and system pwb, front door switches and memory parameter board all have been replaced...also dc power supply. door switches activate transport release solenoid when activated. 24v at door switches. pulled transport unit and activated door switches-get 32-09 fuser jam code. any other suggestions?
dallas
07-01-2010, 08:31 PM
In the past, i have had on a Bizhub 600 the message "Open Door".
In this case, PS38 was failed. Check PS39 also.
Albonline
07-01-2010, 08:53 PM
yep, like he said
Kevin Ransom
07-01-2010, 09:34 PM
Tried ps38/39, swapped entire adu/transport unit, laser. Still no change.
RockETop
07-01-2010, 11:40 PM
That is the End Of Life message for this machine!
With the ADU unit did you also swapped the ADUDB? I had the same error and it was the IC5 on the ADUDB (STK672-120 if i am right) wich had a short.
