View Full Version : KonicaMinolta Bizhub-350 with Faxkit FK-503, dial problems.
Hansoon
07-08-2010, 06:19 PM
Installed a FK-503 faxkit in a BH350. Machine dials a number but somehow the PBX can't handle the dialing. During dialing it gives suddenly the busy tone. However when using the On-Hook-Dial dialing goes through and everything is OK.
Question: Could it be that automatic dialing goes too "fast" for the PBX? Can this somewhere be adjusted in the softswitch settings?
Hans
http://www.qtl.co.il/img/copy.pnghttp://www.google.com/favicon.ico (http://www.google.com/search?q=Installed%20a%20FK-503%20faxkit%20in%20a%20BH350.%20Machine%20dials%2 0a%20number%20but%20somehow%20the%20PBX%20can%27t% 20handle%20the%20dialing.%20During%20dialing%20it% 20gives%20suddenly%20the%20busy%20tone.%20However% 20when%20using%20the%20On-Hook-Dial%20dialing%20goes%20through%20and%20everything %20is%20OK.%0D%0A%0D%0AQuestion:%20Could%20it%20be %20that%20automatic%20dialing%20goes%20too%20%22fa st%22%20for%20the%20PBX?%20Can%20this%20somewhere% 20be%20adjusted%20in%20the%20softswitch%20settings ?%0D%0A%0D%0AHans)http://www.qtl.co.il/img/trans.png
Karelkat
07-09-2010, 07:12 AM
Try soft swich 512 bit 7 0
RRodgers
07-09-2010, 07:43 AM
Sure it's in US and not JP? I see that A LOT!
Hansoon
07-09-2010, 08:19 AM
Dial tone is present after 0-PAUSE so that seems OK. The busy tone is not coming directly but after 3-4 of the 6 digits to dial.
Its working manually when dialing with the ON-Hook feature, but not when setting the original and than entering the tel. number. In that case you can hear in the speaker that it obtains a proper dial tone but within the following dialing sequence it gives suddenly the occupied beeps.
Huh?? Its in Germany and the machine is set to the proper region.
Hans
Karelkat
07-09-2010, 12:18 PM
soft switch 512 bit 7=0
RRodgers
07-09-2010, 05:11 PM
Hans
Sorry, thought you were in the US.
