View Full Version : konica1216
cliffhangers
08-09-2010, 02:33 PM
P26 at power up. SOLUTION ID: 142860
SOLUTION: CAUSE: The L-detect adjustment procedure was not performed, after resetting the PM counter.
SOLUTION: To perform the L-detect adjustment procedure, perform the following:
1. Power the copier OFF.
2. Access the 47 mode (power the copier ON, while pressing the 4 and 7 keys), output code 51.
3. Press the START/PRINT button.
4. The number 51 flashes in the display for approximately 90 seconds.
5. When the number 51 stops flashing, the adjustment is complete.
6. Power the copier OFF/ON to exit the 47 mode.I have perform the L-detect procedure and 51 display for 90 seconds i power the copier OFF/ON it turn bet to F26.please kindly help me it is displaying F26 now.thanks in advance.
Pinoy_Tech
08-09-2010, 04:35 PM
P26 will show after resetting PM counts or when count reached to its cycle but F26 is out of TDS voltage range after running developer setting. Solution; replace new developer and run the setting again.
