Minolta Service Mode Di5510 and Di 3510f
  • ares
    • Jul 2025
    [Misc] Minolta Service Mode Di5510 and Di 3510f
    Hello,
    Can anyone help? I need to format the HDD's on these Minoltas before thay go back to the leasing company. Can someone provide me with how to get into the service mode...
    Thank you...
  • montana
    • Aug 2008
    • 392
    hi...as i recall (utility+stop+0+0+stop+0+1)
    or try utility details stop 0 0 stop 0 1
    i hope it's help.
    • ares
      Thanks I tried that it does not seem to work
      • aesthetics1
        • May 2010
        • 148
        Hello, those are two very different machines.
        For the Di-5510, hold the utility key for several seconds until it asks for a code. enter 92729272 and press start. Alternatively, when you are powering the machine on, you can hold 2 and 5, 3 and 6, etc, to enter their respective modes.
        For the Di-3510f, press utility, and click on the touch screen item that reads "Details" to get into the meter count. From this menu, press Stop + 0 + 0 + Stop + 0 + 1. You may need to enter a password here, which is typically 00000000 (8 zeroes.)
        Hope that works out for you!
        • aesthetics1
          • May 2010
          • 148
          Additionally, I don't believe you can format the Di-5510's hard drive in this mode. The Di-5510 will only have a hard drive in most cases if you have a print controller (looks like a small back-pack type box on the right hand side of the back of the machine.) This contains the hard drive where all of your print jobs/etc will be saved that you would want to get rid of.
          • ares
            Thank you that did it. Do you know how to delete the address book from the Di3510?
            Thanks Again
            • aesthetics1
              • May 2010
              • 148
              Yes. Go to Utility -> User Management -> Fax Input. From there you can select and delete the entries. That's from memory so let me know if that doesn't get you what you want.
              • ares
                Thanks for all your help. That did not do it, what I am trying to do is clear all the names for scan destinations (address book). Figured it out in the Di5510 but this one is different...
                Thank you
                Ares
                • aesthetics1
                  • May 2010
                  • 148
                  Utility > User Setting > Here it should say "E-mail Input" or "Fax Input" > One-Touch > Select each input manually, and select delete when it is available.
                  • ares
                    Thanks,
                    That did it. You're a lifesaver...
                    Thanks again...
                    • aesthetics1
                      • May 2010
                      • 148
                      No problem.
