View Full Version : Electrical bizhub 600 no display
acsolutions
08-24-2010, 07:12 PM
Hello, not sure where to start my bh 600 has no display. the only thing I hear is fan noises and the main power LED is on, on the control panel.
Scijohn23
08-24-2010, 09:13 PM
I would start by checking the connections to the op panel and make sure that they are all seated firmly, then I would check out the power supply for any blown fuses, or anything that is obviously out of place or unusual.
mrwho
08-24-2010, 09:22 PM
I had that twice - you could have either a firmware problem or a malfunctioning control board.
First try to reflash the firmware. If you're unable, you can still take out the boards at the back of the machine and take out the CF cards on the boards. Then you need a another bh600 in working condition - you need to take its CF cards out too and copy the files from the GOOD CF cards onto the BAD CF cards. That one did the trick for me.
Scijohn23
08-24-2010, 09:59 PM
Good answer mrwho,
mrwho
08-24-2010, 11:05 PM
Thanks. :)
