View Full Version : Re: Bizhub 350 Performance
goldencup
10-13-2010, 02:53 PM
Does bizhub 350 come with standard: Printer, scanner and Fax?
Is it a reliable machine?
What problem do you usually encounter on this unit?
Any comment on this model would be highly appreciated. Thanks
BIG PAPA
10-13-2010, 02:59 PM
Fax is not standard. We have had great success with this line. Not many service issues per machine.
emujo
10-13-2010, 03:04 PM
Out of the box, it's a copier/printer/scanner. However, the optional HDD is required for scan to box, and the additional memory (up to 128 meg) is a definate plus. Fax board is an option but works well and is built into the (non universal) print drive so it's easier to use (no seperate fax driver). Decent box and has held up well in most of our locations. Paper supply is weak (not enough supply). Has been replaced by the Bizhub 282, and now the 283 (color scanning). Pretty easy to work on for most routine maintenance. Hope this helps you. Emujo
