View Full Version : C200 Unknown ikon on display
B0265
12-03-2010, 12:26 PM
We have a C200 where the user complains about slow printing (pauses between pages). During printing the display shows an icon at the lower right right side that I have never seen before.
Does anyone know what it stands for?
bizhub1
12-03-2010, 12:38 PM
Not sure if the c200 is the same but with the other color boxes you can push on that symbol and it will bring up a warning message, but it is in the lower left on them.
SmellsHot
12-03-2010, 12:50 PM
I believe it just means that the MFP is receiving data......
B0265
12-03-2010, 12:58 PM
I don't think so, "receive data" have another ikon.
SmellsHot
12-03-2010, 01:42 PM
I know i've seen this before, I think it has something to do with the Hard drive, probably has to be formatted.
SmellsHot
12-03-2010, 01:47 PM
ok, I cant find anything on the exclamation point with color machines, but on the Bizhub 250 this is what the ! means.....
Print jobs fail intermittently. An exclamation mark (!) is displayed on the MFP LCD.
Description:
Intermittent printing error. An exclamation mark (!) is displayed on the control panel.
Solution:
CAUSE: TCP/IP address conflict. This can be verified by disconnecting the network cable from the MFP and using the PING command on a workstation to search for the TCP/IP address that is assigned to the MFP. If there is a reply, a conflict is indicated.
SOLUTION: Assign a unique TCP/IP address to this machine.
SPECIAL NOTE: Solution contribution by Bob Moeller, Production Print/SSD
There is also mention of formatting the hard drive as well when you get the ! on the screen, I would try the IP conflict first, especially since you mentioned slow printing
B0265
12-03-2010, 02:01 PM
Thanks, will check if there's an ip address conflict (the C200 does not have a HDD).
B0265
12-09-2010, 12:24 PM
Customer have verified that the is no ip-address conflict, does anyone have another idea?
SmellsHot
12-09-2010, 01:00 PM
Bummer, now I know that the manual had the "icon" breakdown, but I was just working on a Bizhub 250 and the exclamation point appeared everytime someone was printing something. Those are close to the same age.....but who knows right!?!
Well I'm outta ideas, curious to see if someone can find what it actually means...
emujo
12-09-2010, 01:38 PM
I see this icon every tome I do a config print on any 282 series or older. Don't know what ir means, but I don't think it is a problem, and I think as "Smells Hot" says...just an indication of print data. ( I also know that the green light will light up when printing or coping, but that indicator is on the ADF, maybr serves as the print indicator when ADF is not installed) Emujo
mrwho
12-09-2010, 02:06 PM
Have you tried printing from your own computer with a crossover cable?
B0265
01-17-2011, 12:23 PM
I found this explanation in the Bizhub 250 user manual: "Indicates that computer data waiting to be printed remains".
