View Full Version : Minolta DI650 - copy density problem
jmsaugus
12-12-2010, 04:18 AM
I have a dI650 minolta.
Even if i used maximum copy density, the copy is still pale.
I changed the developper and toner.
no result.
I've also make max auto density adjustement,toner adjustment - nada
need some help.
thanks in advance
Auguste
minimerlin
12-12-2010, 11:00 AM
What is the life on the drum? Is the image on the drum good or is it pale as well? Have you done a full PM lately/ what is PM count? Is the charge good? All these things can affect the copy quality! More details are required before we can try to help.
Are you an end user or a tech?
fixthecopier
12-12-2010, 02:05 PM
And do not forget that tiny gear on the dv box that strips.
minimerlin
12-12-2010, 08:20 PM
And do not forget that tiny gear on the dv box that strips. A good point I forgot about that! I always find it hard to try to remotely diagnose a problem without a scan of the reported fault!
