View Full Version : Minolta Di650 developer
Can anybody out there tell me if the Konica-Minolta Bizhub 600 or 750 developer units will work in a Minolta Di650 I know the part numbers are different but they look almost identical.
fixthecopier
12-13-2010, 09:52 PM
Match the main drive gear on back. One of the reasons it would be different is they changed a couple of the smaller gears so they would not strip. I think it will work.
rocky246
12-13-2010, 11:34 PM
I don't think it fits. There is something different, but I can't remember what it is. It doesn't slide in and fit against the drum.
KonMan
12-14-2010, 12:35 AM
The gears are different. Bizhub 600 are helical, while 650 are straight.
perdana
12-14-2010, 02:48 AM
You can use Developing Unit BZ 600 on DI 650 Machine but you must cut off front and rear side plate about 1 cm. That separate Dev unit and drum.
