Bizhub 7145 streaks on prints
  • svwpa
    • Dec 2010
    • 13
    Our bizhub 7145 developed this streak today. The streaks show up on copies and on prints (from computer). I pulled both of the blue knobs on the front on the copier in and out before this print. That manuver had no change on the streaking. Do you have any ideas on how to fix this problem or what is causing it. See attachment
    Total = 220,000
    52,000 print copies
    Thanks, Mark
  • 173545
    • 16
    Looks like the drum and/or cleaning blade needs replacing.
    • RockETop
      Curmudgeon at large
      • Apr 2007
      • 171
      Yes, that is the cleaning blade.
      • svwpa
        • Dec 2010
        • 13
        Does it make sense that it would go bad in one day. We changed the tonner cartridge 2 weeks ago. No one reported a paper jam. Thanks, Mark
        • mrwho
          Major Asshole!
          • 4299
          It usually happens all of a sudden, and it will get worse if not treated. You can try to just clean up the cleaning blade, but it will probably reappear soon since that is a sign the blade is losing its properties.
          Mascan42
          Ibid
          • svwpa
            • Dec 2010
            • 13
            Shall I replace the cleaning blade itself ($26) or the whole assembly ($75). Thanks, Mark
            • mrwho
              Major Asshole!
              • 4299
              I never had to replace the whole assembly (the drum assembly), so you only need to do it if it is somehow damaged. Usually only the blade is fine, or, if needed, blade+drum. Sometimes you also need to either repair or replace the charge corona (another part of the drum assembly) but the scan you showed us doesn't suggest that.
              Mascan42
              Ibid
              • pepper38_cnd
                Field Service Manager
                • Aug 2005
                • 1075
                You have a pit mark in the drum causing the cleaning blade to skip, replacing the blade alone will only be a temporary fix. Then when it comes back you will have to replace both the blade and the drum. If you look at the pages you have displayed you will see on both pages an area were there is line crossing the vertical streaks that is where the pit mark is and this is where the blade skips.
                Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                Now into Ip TV KODI Boxes
                • mrwho
                  Major Asshole!
                  • 4299
                  Nice! I missed that one, actually. Good job! Replace both the drum and the blade.
                  Mascan42
                  Ibid
