View Full Version : Bizhub c250
joegarzf
01-03-2011, 10:55 AM
Happy New Year to all. Okay, at start up i get code C-B003. I reset it, and it comes up again and again, it wont go away, and of course it will not go to Ready. I don't have service manual for FK502. Please help, thanks a lot¡
KEVIN900
01-03-2011, 11:19 AM
The only information the manual has is to remove & re-insert the fax board, and if that doesn't work, to replace the fax board. I would leave the fax board out of the machine if re-insertion doesn't fix the problem, so at least the customer has the other features available until the fax board is available. I guess it goes without saying to do all this board re-seating with the machine unplugged.
mrwho
01-03-2011, 11:45 AM
Check if the fax board is installed in the correct slot - if it isn't, it will give that error.
NEOTECH
01-03-2011, 03:26 PM
jest only unset or uninstal tha fax board.
mrwho
01-03-2011, 03:50 PM
ROTFL!
"The copier is malfunctioning!"
"Just don't use it!"
