View Full Version : Bizhub 500 blue screen
black dust
01-04-2011, 10:58 PM
Hi there I have a Bizhub B&W which I tried o upgrade firmware……
It worked until I turn the machine off…..
Now I get a blue screen and after a 3-5 sec the DATA led turns on but nothing else…
I tried another ram pack and nothing (from another biz 500- just to see if turns on or not)
Downunder
01-05-2011, 10:06 AM
Hi there pretty sure that you will have to redo firmware. What was the initial firmware? Might need to start with version 20, and maybe ganges boot.
mo0651
01-05-2011, 06:10 PM
What Version are you going to and what version Are you at. I think at version 20 you do the boot and then when the screen comes up blank, start the firmware and ignore screen and it will work. Follow the readme instructions.
copytechman
01-05-2011, 07:04 PM
Nvram can do this too!
Just sayin!.
A!
SmellsHot
01-05-2011, 08:24 PM
Firmware related. Like what was previously mentioned, you will more than likely have to reflash the f/w. Send the boot (ganges) file first than follow it up with ver20. Then upgrade to ver 31 after that....gotta do it in stages depending on the level of f/w
black dust
01-05-2011, 09:45 PM
Just sayin!.
A!
Thanks for the response but I got another Nvram from I costumer which loaned to me over the holydays and it did the same thing….
anyhow does anyone have the boot (ganges) file and the ver 20 file(F/W)????
Kmdurrin
01-05-2011, 11:43 PM
You can extract the boot sector by making a small adjustment to the ISW firmware program. I'll see if I can find the bulletin on it.
BeardedOne
01-06-2011, 06:34 AM
Sounds like the NVRam to me... If you swap it out then you have to use the hard meter.
pepper38_cnd
01-06-2011, 11:16 AM
The easiest fastest fix, is if you have a working BH 500, copy the files from its CF Card ( be careful not to format the card )and paste them onto the CF Card of the non working machine. The only issue with using this method is all the information from the working machine ends up in the other machine so you have to do some reconfiguring once its up and working.
Kmdurrin
01-06-2011, 03:05 PM
SOLUTION: To enable the boot file to be loaded into the ISW utility, perform the following:
1. Using Notepad (or another text editor) open the ”ISWTrns.INI” file from the C:\Program Files\KONICA MINOLTA\ISWTrns folder.
2. In the environment setting, change [EASYTRNS_MENU_DISPLAY] from [FALSE] to [TRUE] and save the file.
3. Restart the ISWTrns tool.
4. In ISW, Select the [EasyTrnsFile (T)] dialog from the Options(O) menu.
5. Browse to the boot file.
The boot file is in the version 20 firmware.
black dust
01-17-2011, 11:24 PM
does anyone have firmware version 20??
stryker3k
01-17-2011, 11:51 PM
I have Ver 31 Only. I Have gone straight to that before after a F/W F***up. Have you tried just reloading what F/W you have? Just a thought.
black dust
01-20-2011, 09:14 PM
I have a bin file named
50ge000m0g140000.bin
does any one have the 20 or 31 version???
this could be use to upload:
http://www.megaupload.com/
