View Full Version : Dual Fax for Taskalfa
jazzih
01-06-2011, 02:33 AM
Hi Experts,
Need help on the dual fax issue. I have install dual fax kit in the MFP, Can anyone teach me how do I send fax using line 2. Is there a steps or icon in the control panel or setting need to be done?
Thank you in advance.
blackcat4866
01-07-2011, 02:53 AM
I don't have any of these in the field, but my understanding is that you only transmit on line 1, but can receive on line 1 and line 2 simultaneously. Does anyone know differently?
tmaged
01-07-2011, 03:21 AM
7825
When setting a default reception port through the command center, the other defaults to the transmission port.
blackcat4866
01-07-2011, 03:47 AM
Thanks Tony. =^..^=
jazzih
01-10-2011, 08:02 AM
Thanks for the feedback,
Does this mean I'm unable to send fax using Line 2?
Or when you send fax, the machine will automactically see if line 1 is busy receiving, it will use line 2?
tmaged
01-13-2011, 03:19 AM
That I'm not really sure about. I just set up the normal "published" fax number as the reception line & the "unknown" line as the sending line.
