View Full Version : Error Code C6751 C200Lite
lanierboy
01-10-2011, 02:51 PM
Hi All,
I have a C200Lite with C6751 CCD Clamp error, I have cleaned all the optics etc but the error will not clear.
before i go and spend a fortune on the machine has anyone had this before,cure??
many thanks
Stirton.M
01-11-2011, 01:43 AM
19.5.97 C6751: CCD clamp/gain adjustment failure
Relevant parts
MFP board (MFPB) CCD board (CCDB)
Step Action
WIRING DIAGRAM
Control signal
Location (Electrical
component)
1 Select [Service Mode] → [State Confirmation]
→ [Memory/HDD Adj.] → [Memory
Bus Check] → [Scanner→Memory], and
conduct the memory bus function.
2 Check the connectors between scanner
section and MFPB for proper connection
and correct as necessary.
3 Change MFPB — —
4 Change CCDB — —
Relevant parts
Exposure unit CCD board (CCDB)
MFP board (MFPB)
Step Action
WIRING DIAGRAM
Control signal
component)
1 Check the connector between CCDB PJ2-
MFPB PJ01 for proper connection and correct
as necessary.
2 Check for possible extraneous light and
3 Clean the lens, mirrors, CCD surface, and
shading sheet if dirty
4 Correct reflective mirror of the scanner if
faulty, or change scanner.
5 Change CCDB — —
6 Change MFPB — —
