View Full Version : Miscellaneous Kyoecra FS- 8008 print problem
drazen7777
01-24-2011, 02:09 PM
I have a problem with mentioned kyo , and the problem is this , every second , third fourth or so , print came out like it is washed out , did someone had similar problems and could give me a hint?
Regards
Drazen
taskalfaman
01-31-2011, 03:33 PM
hi,
in the past i had the same problem.
check whether the solenoid of the sec transfer is not "hanging", are releases too late.
please also check the clutches of the dev. units;
drazen7777
01-31-2011, 05:46 PM
Thanks for reply , i solved it last week . You are wright ,the problem was with the solenoid of the secondary transfer(all rusty inside) he was late and give me a lot of trouble until i figured out that he was the problem. Thank you again . Best regards.
Sent from my HTC Desire using Tapatalk
