View Full Version : LJ 4200dtns
otuvak
01-30-2011, 12:23 AM
This machine has approx 120000 pages on it. It went through its original fuser and a remanned in about 10-11 months and had 11000 pages on the reman fuser. Is there something known on these machines for chewing up fusers or an update?
Meach
01-30-2011, 01:14 AM
There is a ton of poorly remanned fusers on the market. Also, Not uncommon to have the original last only 100K. The HP LJ4200dtns was product launched in 2002.
SO if you just repalced the original fuser 10 months ago you have nothing to complain about.
Jeff M.
01-30-2011, 11:03 AM
Agree with Meach. HP had lots of trouble with 4200 fuser films tearing up. Seems to have gotten better lately, but some remans still are trouble. I use TSAworld remans, have pretty good luck with them. Hope this helps..... Jeff M.
Bri Ski
02-03-2011, 10:00 PM
Tsa complete units are good!
blackcat4866
02-03-2011, 10:59 PM
Could you be talking about gear damage? Take a look at the swing plate (fuser coupler gears in the side frame). =^..^=
907tec
02-03-2011, 11:44 PM
Agree with BlackCat. There was a mod issued for the swing gear assembly that drives the fuser. If you see a little pile of brown dust beneath the fuser drive gears...order the swing gear kit.
prntrfxr
02-04-2011, 02:04 PM
If the white gear behind the black one in the swing plate is also worn, you need to replace the whole swing plate, not just the kit.
emtguy
02-18-2011, 03:36 AM
replace the swingplate brown gear and use the spacer...i use TSA everyday but i never buy a fuser if i can replace the film...
prntrfxr
02-18-2011, 01:19 PM
If you replace the film in the fuser, make sure while you're in there to inspect the pressure bushings. I believe the bushings causes vibration and that that is what causes the swing plates to fail prematurely.
