View Full Version : What in H*ll is this. KM C203
prints Pink overall, also in framingarea, but only in colormode.
B/W copies/prints are OK.
IU IS renewed.
LEO
CKiiza
02-07-2011, 11:26 AM
It's probably the magenta print head that's having a problem.
Switch it with cyan unit. if the background is cyan then you will have to change the print head
mrwho
02-07-2011, 12:04 PM
Either that or an HV contact is bent or broken.
I've also had problems on a C250 with a bad flat cable at the back of the machine, although I don't know the equivalent of that problem on the C203.
When you say IU is renewed you mean it is new and not chipped or rebuilt.
thats correct, changed with a new KM IU,
SmellsHot
02-07-2011, 01:21 PM
yes definetely a print head issue! They had a bulletin out where they were replacing all PH units FOC...they were having a very high failure rate....
bulletin, yes i knew this but all prinhead had been replaced before, ca 2 monhts ago, so i thought....
if u send in the prinhead to claim warranty the printhead will (probably) be fixed at the factory or somwhere and sent out in the field again.
the PHD assy that I putted in the first time had been in for factoryfix.
Yes it was the printhead.
