View Full Version : Minolta Di550 produces fading copies
nizar642
02-07-2011, 01:41 PM
Hi,
Well, i have a Konica Minolta DI550, and recently it started making "fading" copies, although the toner is fairly full and the drum is still new, Please see the following image, Is it the developer?
http://i.imgur.com/MgM8o.png
fixthecopier
02-07-2011, 07:32 PM
It could be the charge, the transfer, the developer...Stop the machine in the middle of a copy and see what it looks like on the drum. If the image is solid on the drum, then you have a transfer issue. Drums and developer usually go the same on a Minolta, why was the developer not changed if the drum is new?
nizar642
02-08-2011, 06:58 AM
Hi,
Thanks for the answer, i don't know where the transfer is as i'm not really familiar with the machine parts in english, btw, we didn't just bought the machine, we replaced the drum with a new one. what do you think?
Downunder
02-08-2011, 08:18 AM
Is that a copy from the glass or an internal print test page? If from the glass then maybe your optics need a good clean. If same from glass and internal print I would be looking at cleaning transsep wires, etc. You might need to do an F5 . And if the drum was replaced I would add my comments to "fixthecopier". Sometimes just scraping the corona wires very gently can improve. One thing you can try is spooning some toner into the dev box and see if that makes a difference.
fixthecopier
02-08-2011, 10:31 AM
Hi,
The transfer is what pulls the image off the drum. If you still do not know, then you should call a tech.
nizar642
02-08-2011, 01:37 PM
Hmm, i can't even find that transfer on google, is it the corona? i would totally appreciate an image url. i did what you've told me ( stopping the machine in the middle of the copy ) and it's not solid on the drum, thanks a lot
fixthecopier
02-08-2011, 09:00 PM
If it is not solid on the drum, it could be the charge corona that sits above the drum. It may need a new grid and new corona wires.
eg101
02-08-2011, 09:37 PM
If you replaced the drum, did you reset the drum counter?
nizar642
02-08-2011, 11:00 PM
Thanks for your help, Here is an other test by the way:
Just in case you have a different explanation, I've stopped the machine while it prints:
http://i.imgur.com/YMWZM.png
minimerlin
02-08-2011, 11:18 PM
What about internal test prints? Looks like dirty optics as previously suggested .
Hansoon
02-09-2011, 05:46 AM
How about a dirty slit glass?
Hans
nizar642
02-12-2011, 08:25 AM
Thank you all for your help, although the problem is that the sponge joint was stuck inside the developer box and it avoids the ink to go through to the paper. Thanks again to everyone here.
Hansoon
02-12-2011, 11:47 AM
"Sponge Joint"???
Hans
