View Full Version : Minolta Di450 error code C1330
copierworks
06-25-2007, 03:17 AM
Can someone help me with this code.the manual only says that it has
something to do with the vd. Dont have any clue.
thanks,
Robert
dqydj
06-25-2007, 09:51 PM
laser code.
it's either the laser the A board or the power supply.
Most likely the laser
dudley
07-03-2007, 04:13 AM
VD is vertical direction, it means that the copier cannot tell how long the paper is. I used to get this on the di620PE with TRmicropress. If I remember right, clean or change the feed rolls as well as clean and lube the sync rollers,transport rollers and bushings.Also clean all the sensors in the sync section. It may also be a sticking sensor flag(damn its been a long time since I did B/W)
BTW the only manual with the damn acronyms explained is the Di30 manual! Of course that model was never sold in Canada but we got our hands on one and got the manual for it. If you can find or down load that manual it fills in a lot of blanks.
