View Full Version : Ricoh 2045 error code 395
satogoya
07-10-2007, 04:55 PM
hey guys, im new in ricoh products and happened to run into a sc 305 error code could anyone please tell me how may I resolve it or deal with it
thanks
Tonerbomb
07-10-2007, 05:56 PM
305 is not listed in my book, but 304 is a charge roller error.check the drum unit. If it's 395 that's a development bias error, check and reset the developer. Power off/on to clear both.
satogoya
07-11-2007, 04:48 AM
yeah thanks for pointin it out i meant 395 and thanks for the answer.
JustManuals
07-11-2007, 08:00 PM
I've got a file of Ricoh Error Codes posted on one of my sites at:
Manuals 4 You - Free (http://www.manuals4you.com/free.htm) Feel free to buy something while you're there. (Baby needs a new pair of shoes)
Paul@justmanuals.com
Tonerbomb
07-12-2007, 12:50 AM
Your relentless ! The sign of a true salesman, weather it's copier manuals or used copiers.
satogoya
07-12-2007, 01:03 AM
well today went to the customer and the 395 code was there and after trying to reset de developer was still there and after a while code 402 came up and threw me off balance even more, i even put a new developer unit in the copier :confused::confused::confused::(:(
Cipher
07-12-2007, 08:34 AM
SC402 could be directly related to the SC395 problem as both may occur if the high voltage board is faulty.
Paper_Jam
07-15-2007, 02:27 PM
Did you notice alot of toner inside the front cover? Those machines had problems with getting toner into the door switches that are just above the fuser. There was a bulletin on that I think but I'm not able to find it right now.
satogoya
07-15-2007, 03:07 PM
actually now that i think of it there was..
Tonerbomb
07-16-2007, 01:05 AM
Props to Paper Jam! there was an issue with the switches and the wireing harness to them, chaffing. You should check them and the harness. Then check your transfer unit and the clutch for the transfer unit.
ganc67
09-29-2007, 10:00 PM
you will need to completely change all components related to copy quality. dev. drum. transfer. main charge and make sure you do the td and id sensor adjustments after. And please do not use any after market parts
satogoya
09-29-2007, 10:35 PM
dont worry i dont work in that sh!t anymore I quit
ganc67
09-29-2007, 10:42 PM
you still on yahoo?
