View Full Version : Xerox M24 Color Copier
higherlevel
07-16-2007, 07:03 PM
Any one had a Wrinkling problem with a M24 Color Copier....Changed a new fuser, still has wrinkling, SOMETIMES....
Letter or Legal...does not matter....Duplex seemd to be the most problem..but has happened on single side also...
techguy75
10-15-2007, 09:31 PM
what lb paper are you using and is the machine set for the right kind of paper also is it in a damp or humid place? alot of times moisture alone causes that problem but can be crappy paper also.
higherlevel
10-16-2007, 12:31 AM
Thanks for the Response....:)
20lb is being used for the 11 x 17 paper....
Paper is fine...
This problem has occured at 2 different customers locations with this machine...We ended up changing the fuser, (EVEN THOUGH THE FUSER LOOKS GOOD) at both locations and it has fixed the problem...
