View Full Version : Error Code Bizhub 360 B&W Help
conano7o
03-18-2011, 06:10 PM
Hello i have a bizhub 360 and i have an error on the screen that says close section properly and the arrow points to tray 1. I dont know why this is and the machine will not operate. I had to do a service on the machine and clean the toner postion sensor etc. I did not touch the tray? Also i went in and tried to clear the trouble codes to see if that would work with no such luck. Also when the error comes up i cant access service mode i have to go into trouble mode then service mode. Any help is appreciated. Thanks!
aesthetics1
03-18-2011, 06:50 PM
Go into service mode and check your sensor operation. See if you have a door sensor mis-aligned or see if one popped loose.
conano7o
03-18-2011, 10:20 PM
Ok well i already had it apart to fix and I noticed that when you close tray 1 it hits a white sensor in the back and it's supposed to turn and lift up paper tray but it doesn't turn?
CT Copier Repair
03-18-2011, 10:33 PM
Check the sensors in service mode
if you don't know how to check in service mode then
find someone who knows how to service the machine
RRodgers
03-18-2011, 11:01 PM
Are you sure there is no paper right behind tray one? I see stuff back there all the time.
conano7o
03-19-2011, 09:34 PM
Ok im not the technician for the machine im the in house IT guy. I took it upon my self to try to fix the machine. I know how to get into service mode but what code do i use to test the paper lift motor/4 (m125)? Basically when the tray is closed the motor doesnt turn when pressure is applied on the sensor.
conano7o
03-19-2011, 11:52 PM
Ok i ruled out it being the paper lift motor. I took the one out i thought was faulty and plugged into tray 2 and it works. So now my question is what is causing that motor not to get power?
pinoyprinter
03-20-2011, 01:27 AM
its a sensor that cause u the trouble test each sensor to tray 2
conano7o
03-20-2011, 01:29 AM
Ok how about disabling the tray so i can use the machine?
pinoyprinter
03-20-2011, 01:33 AM
try not closing the tray 1, pull it off then dont close it, turn off ur printer and turn it on while tray 1 is out/open.
conano7o
03-20-2011, 02:08 AM
Ok well i have tray 1 completely out. Its still giving me the message close section properly and pointing to tray 1
