View Full Version : sharp AR-M236
technician
03-25-2011, 02:19 AM
hello everbody
In the sharp AR-M236 error display U9 subcode 99
how to reset this code
THANKS
blackcat4866
03-25-2011, 02:32 AM
How interesting! U9-99 is an operation panel language error. Did you, by any chance, change the display language recently?
The manual says to set the machine destination in simulation 26-06. There does not appear to be any list of destinations in the manual to choose from. =^..^=
There is another possibility:
- U9-99 can occur if the incorrect firmware is installed, such as DSK firmware on a non-DSK machine, or vice-versa.
- Make sure the correct version of MCU firmware is installed for the country located. Firmware obtained elsewhere will also give U9-99. Reload the MCU firmware with correct F/W.
- Set correct language in sim 26-22 to match firmware file of origin.
JustManuals
03-25-2011, 04:53 AM
Just Manuals | The Internet's largest selection of manuals | Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
technician
03-26-2011, 02:26 AM
if you any solution tell me. dont ask to purchase please
technician
03-26-2011, 02:32 AM
thanks brother.
after i can check language and country then i will tell you.
but there is no firmware installed recently.
soo i wish to find out the problem
thanks again
DINGO
04-08-2011, 10:16 PM
blackat4866
thanks friend, thatīs the solution.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
blackcat4866
04-09-2011, 12:28 AM
What setting did you use for 26-06, for which language?
DINGO
04-09-2011, 11:09 AM
Blackcat4866, i mean that you are 100% right, already happened to me a lot of times, and always was the 26_06 choices wrongs, destination vs language.
enjoy your weekend
