View Full Version : A0-01 in ar-m236
DINGO
04-02-2011, 07:21 PM
Hello
I get a code A0-01 in one AR-M236 when i try instal a fx7 fax module.
one thyng i`m sure, the fax fx7 is good, and work good in other ar-m236 copier.
any help, i`m glad
regards
tmaged
04-02-2011, 09:35 PM
A0 01 Content Security incompatibility error
Details When the PCL or the FAX board is
installed, it does not match with
compatible/incompatible setup of the MCU
board security.
Cause The security compatibility/incompatibility of
the installed PCL or FAX board does not
match with that of the MCU board.
Check
and
remedy
Cheek the security compatibility/
incompatibility of each board. Match the
security compatibility/incompatibility of the
boards.
You may need to update ALL firmware. Machine/fax/print
DINGO
04-02-2011, 10:15 PM
Good,
`ve thought about it
but i`m afraid to damage the copier.
blackcat4866
04-03-2011, 03:19 PM
That's a reasonable concern. Updating firmware on several models of Sharp copiers is a risky business. And you'll require a converter board of some sort. I'll see what I can find out. =^..^=
tmaged
04-03-2011, 04:15 PM
Unless you have a computer with a serial port, you'll need a USB to serial cable. I've done quite a few of these. There shouldn't be any other issues.
DINGO
04-03-2011, 06:02 PM
hello
all oused,
