View Full Version : Konica Minolta Di 7210 Edh Registration
Rudi
07-26-2007, 07:20 AM
HI ALL
I SEEM TO HAVE A PROBLEM ON A DI 7210 , WHERE THE REGISTRATION IS ABOUT 20 mm OUT WHEN COPYING THROUGH THE EDH , FROM THE GLASS ITS FINE .
ANY SUGGESTIONS OR ADVICE PLEASE.
ps. I DID REPLACE THE TAKE UP , FEED , SEP ROLLERS AND ALSO THE CLUTCH AT THE BACK ON THE DRIVE SECTION.
tashima
10-06-2007, 11:47 PM
you must to see in the edh menu the correspondient item to advance the reg to desired measure
Rudi
10-07-2007, 01:47 PM
I Did Check , But The Cut Off Was Not Permanent It Was Intermitend Wat I Did Find Was Replacing The White Guide That Sits Right Above The Reader Glass When Closing The Edh Helped And Also Losening The 3 Screws Left Of The Edh Wich Adjusts The Presure On The Transport Roller Helped Too.
